Date/Time: Mon, 23 Nov 2026 08:08:42 +0000
How to programmatically set the Pointer, Values/Crosshair and Hand tools
View Count: 428
| [2026-01-15 09:25:57] |
| MandelBro - Posts: 28 |
Dear engineers! Is it possible to programmatically set the following tools: 'Pointer', 'Values/Crosshair' and 'Hand'? UseTool::DrawingType enumerates only drawing tools. I can't find a solution. Thank you! |
| [2026-07-07 20:10:31] |
| Sierra_Chart Engineering - Posts: 25463 |
This will be out in the next release: int32_t(SCDLLCALL* SetActiveDrawingTool)(int32_t ChartNumber, DrawingTypeEnum DrawingType, int32_t AllowChangeOfToolInOtherCharts); We have added drawing types for Chart Values and the Hand Tools. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-07-07 20:10:56
