Date/Time: Wed, 25 Nov 2026 22:26:21 +0000
Problem after Transferring Sierra Settings and Data From Existing Installation to New
View Count: 438
| [2026-01-15 08:08:13] |
| User981597 - Posts: 2 |
Hello, and Happy new year. Just recently changed my computer... and followed the process of "Transferring Sierra Chart Settings and Data From Existing Installation to New Installation". In the beginning, looked perfectly fine, but just realized its freezing at some moments. Yesterday I tried to update Sierra´s version but it stopped and at the the end its saying: "MD5 file does not match |
| [2026-01-15 16:45:29] |
Use the Zip Installer to update and then see how things are functioning. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
