Date/Time: Wed, 25 Nov 2026 22:26:19 +0000
Is there any way to hide the TPOs from a TPO Chart (yes i know this is a dumb question)
View Count: 420
[2026-01-15 04:14:16]
User172061 - Posts: 36
I'm using a chartbook that has a wonderful daily volume profile chart attached to a TPO chart. I know this is probably a dumb question, but is there any way to hide the TPO part of this chart...or a simple way to recreate this without going item by item as a daily volume chart?
I understand that the answer to this is probably no, but i figured i would ask before spending hours trying to recreate this 1 chart just without the TPOs.
Thanks for taking the time to answer this one John.
Private File
[2026-01-15 16:35:57]
There is no way to "hide" the TPOs, so the only remaining option is to remove it. But in so doing, the Volume by Price will revert to its original state, which probably is not the settings you want.
Therefore, in the end, you will have to rebuild the chart without the TPOs. We recommend duplicating the chart and working from the duplicate, so you have the original around.
