Date/Time: Wed, 25 Nov 2026 22:26:20 +0000
Relative volume not displaying on Daily Chart
View Count: 382
[2026-01-15 02:45:04]
User794005 - Posts: 51
I used to use 4 hour charts earlier until recently when i switched using Daily instead of 4hour. I had to go in the chart settings and change from '0-240-0' to 1-0-0 to start using daily charts. Ever since i did that, relative volume stopped popping up. I have attached the pictures. The relative volume is the bottom chart below the CVD chart, and shows blank.
imageScreenshot 2026-01-14 at 9.40.51 PM.png / V - Attached On 2026-01-15 02:44:32 UTC - Size: 197.94 KB - 215 views
imageScreenshot 2026-01-14 at 9.42.29 PM.png / V - Attached On 2026-01-15 02:44:36 UTC - Size: 118.08 KB - 218 views
[2026-01-15 16:15:18]
The Relative Volume study works by looking at the previous bars with the same time. Since daily bars do not have specific time associated with them, this study does not work properly for daily (and higher timeframe) bars.
