Date/Time: Wed, 25 Nov 2026 22:21:07 +0000
Title bar text version 2862
View Count: 414
[2026-01-13 20:36:20]
User431178 - Posts: 910
In version 2862 the title bar text vertical alignment seems a bit off when compared to 2861.
I made an image of each for reference.
imagetitle bar text 2861.png / V - Attached On 2026-01-13 20:35:27 UTC - Size: 29.29 KB - 198 views
imagetitle bar text 2862.png / V - Attached On 2026-01-13 20:35:37 UTC - Size: 29.33 KB - 222 views
[2026-01-13 21:03:55]
Sierra_Chart Engineering - Posts: 25484
Are you using OpenGL?
We made a change to make it perfectly centered but we can see there is an issue apparently when using OpenGL.
[2026-01-13 21:17:19]
Yes, that was with OpenGL enabled.
It is perfect when not using OpenGL.
[2026-01-13 22:13:39]
We will work on this.
