Date/Time: Wed, 25 Nov 2026 22:21:05 +0000
AMP CQG REACTIVATION DENALI NO DATA
View Count: 559
[2026-01-13 20:18:05]
User143681 - Posts: 52
AMP balance lapsed and required funding and submitting Existing Setup request to reactivate data feed, i used same as prior by selecting CQG with CME data.
CQG website login is working with real time data. Sierrachart displays Real-Time market data only supported with Sierra Chart data feed for symbol F.US.EPH26. Historical download data failed only supported with sierra chart data feed.
Sierrchart account is approved with active data exchanges. Settings as Select Global Settings >> Data/Trade Service Settings >> Common Settings. Enable Allow Support for Sierra Chart Data Feeds is correct. Main settings selected service is CQG WebAPI.
This was my preferred configuration, with data feed from denali and routing with CQG.
All worked prior before the AMP account required funding and reactivation. Other change was updating SC to the current version.
Please advise, thank you.
[2026-01-13 20:40:41]
The exchange that you had active on our Denali Exchange Data Feed for the CME Group did not automatically renew on January 1, 2026, due to insufficient funds in your account at that time.
You can activate the exchange(s) for which you want real-time data for the CME Group at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
You may need to add funds to your account. You do this at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit#MoveToTop
[2026-01-14 03:19:56]
Denali Exchange Data Feed Service (Optional): [✔]- Your Service Package supports activating exchanges with the Denali Data Feed.
As shown above the service package supports activating exchanges. Could you provide the breakdown of subscription and fees and how applied?
Doesn't the package include market depth and explain if the additional exchange costs are necessary?
[2026-01-14 13:04:57]
Sierra_Chart Engineering - Posts: 25484
Refer to this page:
https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices
There are exchange fees for real-time data. You currently do not have any exchanges available.
