Date/Time: Tue, 24 Nov 2026 07:47:47 +0000
Numbers bars OPTION REAL Transparency!
View Count: 670
| [2026-01-13 19:05:13] |
| TopGunTrader - Posts: 313 |
Hi, This has bugged me for years but now that I'm marking more levels and with rectangle boxes really does. I want option to have real transparency. In this example I show the underlying bar with delta to the right. I have to color the background OR it doesn't show that row and it messes up the alignment of row2. When I do this is looks ok most of the time until it goes over a colored box then looks absolutely horrible. I think this can be done in 2 ways option to have REAL transparency so column 2 isn't shifted over OR a RGB color that will make it transparent something weird nobody would use like 186, 1, 214 or something very bizarre where it would be 1 out of 500k chance anybody ever picks that color. Can you guys fix this I realize its not really broken but in a way it is for those who mark a lot on their charts. I'd also love to be able to get rid of wasted space and have candles closer so I can see more data. A good 35-40% of chart is wasted by doing this workout. |
| [2026-08-31 11:54:10] |
| User783786 - Posts: 9 |
I wanted to add another vote to add a fill transparency % to background coloring for numbers bars study.
| [2026-11-07 11:00:30] |
| gammamale - Posts: 12 |
Yes I also am looking for Number Bars transparency % background color. There is already background color "None - Transparent" but that is turning off any Background Coloring Method for coloring that segment e.g. Bid Ask Difference. Ideally I would like to choose the background as transparent for most ranges of Bid Ask Difference values (i.e. not extreme values) but then have the background some bright color (e.g. yellow) for extreme numbers. As of now, I approximate this by having the Background as None - Transparent and having the individual Numbers themselves black (unnoticable) for most range number and Yellow for extreme numbers. The benefit is this doesn't block out or cover over too much viewing whatever is behind the Number Bar. It does block out a little bit with the outlines of the black numbers but it's not too bad. |
