Date/Time: Thu, 26 Nov 2026 04:33:44 +0000
When I switch between the tools the cursor does NOT change until I move the mouse
View Count: 411
| [2026-01-13 04:05:40] |
| MandelBro - Posts: 28 |
Dear Ńolleagues! I have two requests for you. 1. I use hotkeys to switch between tools: 'Pointer', 'Values/Crosshair' and 'Hand'. The cursor of the chosen tool changes only after I move the mouse. Please reflect my selection when mouse remains at rest. 2. Please change both cursors for 'Hand' in order that they will be somehow different from the ones of 'Pointer', f.e. when left mouse button is released this could be an open hand and when it is pressed - a fist (drag-mode). Is it possible? Thank you! Date Time Of Last Edit: 2026-01-13 14:40:10
| [2026-01-13 15:27:07] |
1. This is how the Operating System is dealing with it, there is nothing we can do to change how this functions. 2. We have noted this request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-15 15:26:11] |
| Sierra_Chart Engineering - Posts: 25491 |
1. We are not going to get involved in this. We do not have control over this and we are not going to try to figure out how to do this. 2. We fundamentally disagree with this and will not get involved in this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
