Date/Time: Wed, 25 Nov 2026 22:21:06 +0000
Bug: Black volume bar showing on the graph on start-up
View Count: 370
[2026-01-12 20:29:01]
Cc79021!c12773 - Posts: 1
The black bar always automatically loads on start-up since the evening session today. When I hover over the volume study, it changes from having 10 rows as you see here into 3 rows, with the last row displaying the exact number value of volume for that bar. Even when I delete the volume study, the black columns remain on my screen, and I have no way of taking them off. All i can do is drag them around the screen. Please assist.
https://www.sierrachart.com/image.php?Image=1768190869158.png
[2026-01-12 20:31:34]
Those black boxes look like the "Compact Tool Values Window", but with the values not showing because the color is most likely set to "Black".
Select "Window >> Show Compact Tool Values Window" to remove the checkmark next to that option and see if those black boxes go away. If they do, then this is what it is.
In this case, if you want to view the text in that window, then set the following to be something other than black:
Graphics Settings: Chart Values Window Default Text Color
In the Graphics Settings window:
Graphics Settings: Introduction
Date Time Of Last Edit: 2026-01-31 20:17:35
