Date/Time: Wed, 25 Nov 2026 22:21:10 +0000
Windows > Tile Vertically leaves large gap in bottom of main window
View Count: 403
| [2026-01-12 18:25:07] |
| opmetal - Posts: 78 |
Before the MDI updates the Windows> "Tile Vertically" button would tile my windows to take up the entirety of the main window. Now it leaves about a 10% gap between the bottom of any chart and the bottom of the main window so that I have to manually drag the bottom of the chart all the way down. How to fix this so it works like it did before? Thanks.
| [2026-01-12 22:28:57] |
I've resolved this via setting this to Yes: Global Settings > General Settings > GUI > Ignore Minimized Windows When Tiling
| [2026-01-12 23:32:04] |
| Sierra_Chart Engineering - Posts: 25484 |
We are implementing a solution for this in the next release. Also that option does make sense. But we completely forgot about it. But there still was something else related to this that we needed to solve. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-12 23:32:12
