Date/Time: Wed, 25 Nov 2026 22:21:11 +0000
Swing high/ low study
View Count: 484
| [2026-01-11 17:18:57] |
| pavel.lysenka - Posts: 50 |
How can i display the Price instead of the arrows on top/bottom of the bars.
| [2026-01-12 16:26:47] |
If you want the value of the High/Low where the Swing High/Low occurs, then you need to set the following in the Swing High/Low study: - Arrow Offset as Percentage: 0 And in the Subgraph tab for the study set the following for both the "Swing High" and "Swing Low" subgraphs: - Draw Style: Value on High (for the Swing High subgraph) and Value on Low (for the Swing Low subgraph) - Width/Size: 10 (start at this value and adjust as needed to get the display how you want it). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-12 20:07:21] |
Can i make it not display values next to eachother on a higher timeframe?
| [2026-01-12 21:20:17] |
We assume you are saying that since the text is wider than an arrow, that there can be times when you have multiple values displayed and they are overlapping each other. There is not a way to work around this. The best option would be to play with the Width of the text to find a tradeoff of what you can view versus the overlap. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-13 20:09:16] |
I managed to do it with the Zig Zag study.
