Date/Time: Wed, 25 Nov 2026 22:21:12 +0000
Footprint Data Text File
View Count: 349
[2026-01-10 22:18:10]
User699988 - Posts: 14
Dear Sierra Team,
Is there a way to easily copy the data from the Footprint Bars (specifically the bid and ask values including their price levels) into a text file?
Like this:
Price: 58.71 Bid: 5 Ask: 34
Price: 58.70 Bid: 23 Ask: 10
And so on.
According to an AI, this should be possible; however, none of the methods suggested have worked for me so far.
Thank you very much in advance.
[2026-01-12 16:04:34]
The only way to get this information is to create a custom study. Otherwise the information you are looking for is not readily available through the software. Refer to the following:
ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
