Date/Time: Wed, 25 Nov 2026 22:21:11 +0000
Request : NBCV2 Bid-Ask Pulling/Stacking levels limiter
View Count: 402
| [2026-01-10 19:27:29] |
| Sébastien - Posts: 156 |
Hi, Last year we were granted this wonderful Chart Setting: Maximum Market Depth Pulling Stacking Levels (0 = all levels). Unfortunately it only applies to DOM columns, not the NBCV2. If it's not too difficult / time consuming, would it be possible to make NBCV2 respect this parameter in one of the following updates? Best regards, Sebastien |
| [2026-01-12 16:01:51] |
We are aware that the Chart setting for "Maximum Market Depth Pulling Stacking Levels" does not affect the calculation of the totals for the pulling/stacking columns. This is being looked into, but we can not give a definitive time when it will be done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-12 21:41:52] |
Thank you for your feedback John. Good to know you are aware of it. Have a good evening. |
| [2026-01-13 00:45:45] |
| Sierra_Chart Engineering - Posts: 25484 |
We are aware of it but there is not a practical solution. So there is no consideration at this time as to what to do.
