Date/Time: Wed, 25 Nov 2026 22:50:13 +0000
Add ACSIL variable for “ Market Depth Combine Increment in Ticks”
View Count: 669
| [2026-01-10 05:04:58] |
| gcUserStudies - Posts: 146 |
Request to add a variable so ACSIL studies can read the value for “ Market Depth Combine Increment in Ticks” value. Thanks |
| [2026-01-12 17:46:49] |
| Sierra_Chart Engineering - Posts: 25484 |
We will make a note of this.
| [2026-02-04 19:18:20] |
This will be supported in the next release.
| [2026-02-05 15:34:45] |
Thanks for adding this! I'm testing version 2877 and see the new functions have been added. I have set my chart's "Market Depth Combine Increment in Ticks" set to 2. Then I call the function to get the value, and also try setting the value to 5, and then get the value again. Here are the results. I may be doing something wrong, but wanted to double check. And also checking the value in the chart settings it didn't change to 5 either: ... // Get initial value apiValueBefore = sc.GetMarketDepthCombineIncrementInTicks(sc.ChartNumber); // Try setting to 5 apiSetResult = sc.SetMarketDepthCombineIncrementInTicks(sc.ChartNumber, 5); // Get value again to see if it changed apiValueAfter = sc.GetMarketDepthCombineIncrementInTicks(sc.ChartNumber); ... Log of result: "Debug: SC=2877, ChartNum=1, API_Before=0, Set(5)=0, API_After=0" |
| [2026-02-06 23:00:59] |
Make sure you are running an up-to-date version of Sierra Chart. Use the latest prerelease. Which is at this time 2877.
