Date/Time: Wed, 25 Nov 2026 22:20:47 +0000
SC not seeing compiled dll
View Count: 1145
[2026-01-10 03:47:05]
John M - Posts: 189
I compiled a custom study. The build was successful and the dll file shows in the Data folder but it does not show up in Analysis.
I have done the Release dll and then allow load dll but it still doesn't show up under Analysis and restarted SC.
I have done this multiple times with no success. Current version of SC.
What's wrong ?
thanks.
[2026-01-10 03:52:33]
John M - Posts: 189
An additional bit of information:
When I go to Open Custom DLL it goes to the ACS folder and not the Data folder.
I have the Data folder selected under Paths so I don't understand why it is going to the ACS folder.
When I change folders from ACS to Data, it shows nothing even with a Refresh.
[2026-01-10 04:46:07]
User719512 - Posts: 548
Analysis? Custom studies show up under Analysis >> Studies, or F6, then Add Custom Study
[2026-01-10 05:30:34]
John M - Posts: 189
I know that.
I've only been using SC for 15 years or so...
[2026-01-10 18:40:14]
Sierra_Chart Engineering - Posts: 25484
Are you building with Visual C++ or Remote Build? We need to know which one.
And are you building within Sierra Chart through the Build Advanced Custom Studies window?
[2026-01-10 18:45:52]
John M - Posts: 189
Remote Build and Build Advanced Custom Studies Window
Source code put into ACS folder
[2026-01-10 18:49:08]
John M - Posts: 189
build executed ok and put the dll into the Data folder.
In windows explorer I can see the file in the Data folder.
SC doesn't see it and it looks at the ACS folder when I go to open custom dll even after verifying the path in General Settings.
[2026-01-11 23:53:31]
The DLL file will be put in the correct location after using Remote Build. So you are not moving the DLL file?
[2026-01-12 02:12:55]
John M - Posts: 189
No, I'm not moving it.
It went into the Data file all by itself after the Remote processing.
I can see the file in windows explorer in the Data folder.
SC doesn't see it when I go to New/Open Custom Studies File
and it doesn't appear in the list of Studies under Analysis / F6
so I can't open it.
[2026-01-12 02:26:38]
John M - Posts: 189
-- Starting remote build of Custom Studies Source files: AuclairsDadAlgo2_64.dll.cpp. 64-bit -- 20:24:24
Allow time for the server to compile the files and build the DLL.
Server: https://build2.sierrachart.com
The remote build is complete.
The build succeeded.
The compiler response is empty.
Writing file to: C:\SierraChart\Data\AuclairsDadAlgo2_64.dll_64.dll
-- End of Build -- 20:24:28
[2026-01-12 16:50:21]
Please do the following for us:
- Select "Window >> Message Log"
- Select "Edit >> Clear Log" on the Message Log
- Select "Analysis >> Studies"
Get us the information in the Message Log by following these instructions:
[2026-01-13 04:33:31]
ForgivingComputers.com - Posts: 1256
The dll file name doesn't look right. Try a simple name like test.cpp.
[2026-01-13 05:48:29]
Try renaming the CPP file:
To:
AuclairsDadAlgo2.cpp
