Date/Time: Tue, 27 Oct 2026 17:53:52 +0000
message log
View Count: 428
| [2026-01-09 20:45:12] |
| User512236 - Posts: 1 |
2026-01-09 20:38:42.263 | Trade activity files set size: 1 2026-01-09 20:38:42.267 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-09 20:38:42.268 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2026-01-09 20:38:42.268 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2026-01-09 20:38:42.268 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2026-01-09 20:38:42.319 | Reading Internal Order ID file. 2026-01-09 20:38:42.319 | Reading Trade Orders file. 2026-01-09 20:38:42.320 | Reading Trade Positions file. 2026-01-09 20:38:42.320 | Reading Trade Account Data files. 2026-01-09 20:38:42.321 | Software version: 2859 64-bit 2026-01-09 20:38:42.321 | Primary Thread ID: 5872 2026-01-09 20:38:42.321 | Usage end date: 2026-03-26 2026-01-09 20:38:42.321 | Enabled for: Advanced Features 2. 2026-01-09 20:38:42.321 | Enabled for: Sierra Chart Historical Data Service. 2026-01-09 20:38:42.321 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-01-09 20:38:42.321 | Enabled for: Delayed Denali Exchange Data Feed. 2026-01-09 20:38:42.321 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-01-09 20:38:42.321 | Current selected Data/Trading service: Rithmic Direct - DTC 2026-01-09 20:38:42.321 | Custom symbol settings values: enabled 2026-01-09 20:38:42.321 | Chart Update Interval: 400 2026-01-09 20:38:42.321 | Intraday Data Storage Time Unit: 0 2026-01-09 20:38:42.321 | Time Zone: +00:00:00 (UTC+00) 2026-01-09 20:38:42.321 | 2026-01-09 20:38:42 Local computer time in UTC 2026-01-09 20:38:42.321 | 2026-01-09 20:38:42 Local computer time in SC Time Zone 2026-01-09 20:38:42.321 | 2026-01-09 20:38:41 Server time in UTC 2026-01-09 20:38:42.321 | Local computer UTC time and Server UTC time difference: 1 seconds. 2026-01-09 20:38:42.321 | Program path: C:\SierraChart\ 2026-01-09 20:38:42.321 | Data Files path: C:\SierraChart\Data\ 2026-01-09 20:38:42.322 | OS Version Number: 10.0 2026-01-09 20:38:42.322 | Locale Setting: C 2026-01-09 20:38:42.322 | Crash reporter started: true 2026-01-09 20:38:42.322 | 2026-01-09 20:38:42.322 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2026-01-09 20:38:42.328 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:38:42.340 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-01-09 20:38:42.340 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-01-09 20:38:42.376 | Received 5 login tokens. 2026-01-09 20:38:42.471 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2026-01-09 20:38:42.476 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576 2026-01-09 20:38:42.478 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-09 20:38:42.478 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2026-01-09 20:38:42.479 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-09 20:38:42.479 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2026-01-09 20:38:42.479 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2026-01-09 20:38:42.484 | Symbol settings MD5 received. Request ID: 1. 2026-01-09 20:38:42.484 | Symbol settings are up-to-date for rithmic_v2.trading. 2026-01-09 20:38:44.814 | Requested user files to download. 2026-01-09 20:38:46.817 | 2026-01-09 20:38:46.817 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:38:46.817 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:38:46.817 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:38:46.824 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:38:46.824 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:38:46.825 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:38:46.829 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:38:46.829 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:38:46.829 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:38:46.829 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:38:46.857 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:38:46.857 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:38:46.857 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:38:46.857 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:38:46.857 | Rithmic Direct - DTC | Failed connections: 1 2026-01-09 20:38:46.857 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:38:46.857 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:47.007 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:38:47.007 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:38:47.008 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:38:47.008 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:38:47.008 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:47.012 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:38:47.012 | DTC Client socket (1) | Closed. 2026-01-09 20:38:50.119 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2026-01-09 20:38:51.010 | 2026-01-09 20:38:51.010 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:38:51.010 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:38:51.010 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:38:51.013 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:38:51.014 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:38:51.014 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:38:51.025 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:38:51.025 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:38:51.026 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:38:51.026 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:38:51.048 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:38:51.048 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:38:51.048 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:38:51.048 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:38:51.048 | Rithmic Direct - DTC | Failed connections: 2 2026-01-09 20:38:51.048 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:38:51.048 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:51.057 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:38:51.058 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:38:51.058 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:38:51.058 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:51.058 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:38:51.063 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:38:51.063 | DTC Client socket (1) | Closed. 2026-01-09 20:38:55.051 | 2026-01-09 20:38:55.051 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:38:55.051 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:38:55.051 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:38:55.052 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:38:55.052 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:38:55.052 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:38:55.055 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:38:55.055 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:38:55.055 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:38:55.055 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:38:55.069 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:38:55.069 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:38:55.069 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:38:55.069 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:38:55.069 | Rithmic Direct - DTC | Failed connections: 3 2026-01-09 20:38:55.069 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:38:55.069 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:55.083 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:38:55.083 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:38:55.083 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:38:55.083 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:38:55.083 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:55.086 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:38:55.086 | DTC Client socket (1) | Closed. 2026-01-09 20:38:59.087 | 2026-01-09 20:38:59.087 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:38:59.087 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:38:59.087 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:38:59.088 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:38:59.088 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:38:59.088 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:38:59.091 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:38:59.091 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:38:59.091 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:38:59.091 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:38:59.106 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:38:59.106 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:38:59.106 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:38:59.106 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:38:59.106 | Rithmic Direct - DTC | Failed connections: 4 2026-01-09 20:38:59.106 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:38:59.106 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:59.119 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:38:59.119 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:38:59.119 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:38:59.119 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:38:59.119 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:38:59.122 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:38:59.122 | DTC Client socket (1) | Closed. 2026-01-09 20:39:03.119 | 2026-01-09 20:39:03.119 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:03.119 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:03.119 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:03.122 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:03.122 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:03.122 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:03.125 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:03.125 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:03.125 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:03.125 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:03.139 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:03.139 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:03.139 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:03.139 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:03.139 | Rithmic Direct - DTC | Failed connections: 5 2026-01-09 20:39:03.139 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:03.139 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:03.150 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:03.151 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:03.151 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:03.151 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:03.151 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:03.154 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:03.154 | DTC Client socket (1) | Closed. 2026-01-09 20:39:07.168 | 2026-01-09 20:39:07.169 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:07.169 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:07.169 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:07.175 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:07.176 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:07.176 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:07.181 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:07.181 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:07.181 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:07.181 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:07.225 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:07.225 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:07.225 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:07.225 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:07.225 | Rithmic Direct - DTC | Failed connections: 6 2026-01-09 20:39:07.225 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:07.225 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:07.238 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:07.240 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:07.240 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:07.240 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:07.241 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:07.250 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:07.250 | DTC Client socket (1) | Closed. 2026-01-09 20:39:11.241 | 2026-01-09 20:39:11.241 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:11.241 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:11.241 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:11.241 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:11.242 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:11.242 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:11.244 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:11.244 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:11.244 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:11.244 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:11.258 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:11.258 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:11.258 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:11.258 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:11.258 | Rithmic Direct - DTC | Failed connections: 7 2026-01-09 20:39:11.258 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:11.258 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:11.272 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:11.273 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:11.273 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:11.273 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:11.273 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:11.275 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:11.275 | DTC Client socket (1) | Closed. 2026-01-09 20:39:15.275 | 2026-01-09 20:39:15.275 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:15.275 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:15.275 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:15.276 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:15.276 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:15.276 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:15.280 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:15.280 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:15.280 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:15.280 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:15.298 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:15.298 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:15.298 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:15.298 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:15.298 | Rithmic Direct - DTC | Failed connections: 8 2026-01-09 20:39:15.298 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:15.298 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:15.306 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:15.307 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:15.307 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:15.307 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:15.307 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:15.310 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:15.310 | DTC Client socket (1) | Closed. 2026-01-09 20:39:19.297 | 2026-01-09 20:39:19.297 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:19.297 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:19.297 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:19.300 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:19.300 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:19.300 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:19.303 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:19.303 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:19.303 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:19.303 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:19.317 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:19.317 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:19.317 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:19.317 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:19.317 | Rithmic Direct - DTC | Failed connections: 9 2026-01-09 20:39:19.317 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:19.317 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:19.329 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:19.329 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:19.329 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:19.329 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:19.329 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:19.332 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:19.332 | DTC Client socket (1) | Closed. 2026-01-09 20:39:23.338 | 2026-01-09 20:39:23.338 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:23.338 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:23.338 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:23.339 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:23.339 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:23.339 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:23.341 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:23.341 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:23.341 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:23.341 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:23.355 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:23.355 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:23.355 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:23.355 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:23.355 | Rithmic Direct - DTC | Failed connections: 10 2026-01-09 20:39:23.355 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:23.355 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:23.369 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:23.369 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:23.369 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:23.369 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:23.369 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:23.372 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:23.372 | DTC Client socket (1) | Closed. 2026-01-09 20:39:27.366 | 2026-01-09 20:39:27.366 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:27.366 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:27.366 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:27.404 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:27.404 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:27.404 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:27.406 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:27.406 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:27.406 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:27.406 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:27.419 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:27.419 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:27.419 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:27.419 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:27.419 | Rithmic Direct - DTC | Failed connections: 11 2026-01-09 20:39:27.419 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:27.419 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:27.430 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:27.430 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:27.430 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:27.430 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:27.430 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:27.433 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:27.433 | DTC Client socket (1) | Closed. 2026-01-09 20:39:31.437 | 2026-01-09 20:39:31.437 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:31.437 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:31.437 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:31.443 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:31.444 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:31.444 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:31.448 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:31.448 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:31.449 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:31.449 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:31.478 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:31.478 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:31.478 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:31.478 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:31.478 | Rithmic Direct - DTC | Failed connections: 12 2026-01-09 20:39:31.478 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:31.478 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:31.484 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:31.486 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:31.486 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:31.486 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:31.486 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:31.490 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:31.490 | DTC Client socket (1) | Closed. 2026-01-09 20:39:35.494 | 2026-01-09 20:39:35.494 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:35.494 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:35.494 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:35.497 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:35.497 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:35.497 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:35.500 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:35.500 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:35.500 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:35.500 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:35.520 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:35.520 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:35.520 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:35.520 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:35.520 | Rithmic Direct - DTC | Failed connections: 13 2026-01-09 20:39:35.520 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:35.520 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:35.525 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:35.525 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:35.525 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:35.526 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:35.526 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:35.528 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:35.528 | DTC Client socket (1) | Closed. 2026-01-09 20:39:39.525 | 2026-01-09 20:39:39.525 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:39.525 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:39.525 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:39.526 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:39.527 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:39.527 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:39.529 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:39.529 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:39.529 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:39.529 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:39.543 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:39.543 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:39.543 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:39.543 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:39.543 | Rithmic Direct - DTC | Failed connections: 14 2026-01-09 20:39:39.543 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:39.543 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:39.556 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:39.557 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:39.557 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:39.557 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:39.557 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:39.559 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:39.560 | DTC Client socket (1) | Closed. 2026-01-09 20:39:43.556 | 2026-01-09 20:39:43.556 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:43.556 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:43.556 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:43.557 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:43.557 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:43.557 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:43.560 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:43.560 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:43.560 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:43.560 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:43.576 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:43.576 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:43.576 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:43.576 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:43.576 | Rithmic Direct - DTC | Failed connections: 15 2026-01-09 20:39:43.576 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:43.576 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:43.588 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:43.588 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:43.588 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:43.588 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:43.588 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:43.591 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:43.591 | DTC Client socket (1) | Closed. 2026-01-09 20:39:47.579 | 2026-01-09 20:39:47.579 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:47.579 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:47.579 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:47.583 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:47.584 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:47.584 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:47.602 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:47.602 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:47.602 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:47.602 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:47.628 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:47.628 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:47.628 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:47.628 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:47.628 | Rithmic Direct - DTC | Failed connections: 16 2026-01-09 20:39:47.628 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:47.628 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:47.642 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:47.643 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:47.644 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:47.644 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:47.644 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:47.648 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:47.648 | DTC Client socket (1) | Closed. 2026-01-09 20:39:51.643 | 2026-01-09 20:39:51.643 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:51.643 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:51.643 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:51.647 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:51.647 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:51.647 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:51.650 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:51.650 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:51.650 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:51.650 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:51.669 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:51.669 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:51.669 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:51.669 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:51.669 | Rithmic Direct - DTC | Failed connections: 17 2026-01-09 20:39:51.670 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:51.670 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:51.675 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:51.675 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:51.676 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:51.676 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:51.676 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:51.678 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:51.679 | DTC Client socket (1) | Closed. 2026-01-09 20:39:55.682 | 2026-01-09 20:39:55.682 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:55.682 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:55.682 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:55.683 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:55.683 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:55.683 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:55.685 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:55.685 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:55.686 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:55.686 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:55.700 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:55.700 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:55.700 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:55.700 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:55.700 | Rithmic Direct - DTC | Failed connections: 18 2026-01-09 20:39:55.700 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:55.700 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:55.713 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:55.714 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:55.715 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:55.715 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:55.715 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:55.718 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:55.718 | DTC Client socket (1) | Closed. 2026-01-09 20:39:59.703 | 2026-01-09 20:39:59.704 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:39:59.704 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:39:59.704 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:39:59.706 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:39:59.707 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:39:59.707 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:39:59.711 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:39:59.711 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:39:59.712 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:39:59.712 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:39:59.745 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:39:59.745 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:39:59.745 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:39:59.745 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:39:59.745 | Rithmic Direct - DTC | Failed connections: 19 2026-01-09 20:39:59.745 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:39:59.745 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:59.753 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:39:59.753 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:39:59.754 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:39:59.754 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:39:59.754 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:39:59.757 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:39:59.757 | DTC Client socket (1) | Closed. 2026-01-09 20:40:03.759 | 2026-01-09 20:40:03.760 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:03.760 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:03.760 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:03.760 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:03.760 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:03.760 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:03.763 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:03.763 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:03.763 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:03.763 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:03.776 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:03.776 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:03.776 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:03.776 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:03.776 | Rithmic Direct - DTC | Failed connections: 20 2026-01-09 20:40:03.776 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:03.776 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:03.792 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:03.793 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:03.793 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:03.793 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:03.793 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:03.796 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:03.796 | DTC Client socket (1) | Closed. 2026-01-09 20:40:07.791 | 2026-01-09 20:40:07.791 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:07.791 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:07.791 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:07.794 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:07.794 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:07.794 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:07.797 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:07.797 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:07.797 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:07.797 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:07.811 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:07.811 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:07.811 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:07.811 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:07.811 | Rithmic Direct - DTC | Failed connections: 21 2026-01-09 20:40:07.811 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:07.811 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:07.822 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:07.823 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:07.823 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:07.823 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:07.823 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:07.825 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:07.825 | DTC Client socket (1) | Closed. 2026-01-09 20:40:11.822 | 2026-01-09 20:40:11.822 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:11.822 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:11.822 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:11.823 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:11.823 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:11.823 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:11.825 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:11.825 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:11.825 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:11.825 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:11.839 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:11.839 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:11.839 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:11.839 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:11.839 | Rithmic Direct - DTC | Failed connections: 22 2026-01-09 20:40:11.839 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:11.839 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:11.854 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:11.855 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:11.855 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:11.855 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:11.855 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:11.858 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:11.858 | DTC Client socket (1) | Closed. 2026-01-09 20:40:15.854 | 2026-01-09 20:40:15.854 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:15.854 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:15.854 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:15.855 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:15.856 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:15.856 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:15.859 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:15.859 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:15.859 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:15.859 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:15.876 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:15.876 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:15.876 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:15.876 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:15.876 | Rithmic Direct - DTC | Failed connections: 23 2026-01-09 20:40:15.876 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:15.876 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:15.885 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:15.885 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:15.885 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:15.885 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:15.885 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:15.888 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:15.889 | DTC Client socket (1) | Closed. 2026-01-09 20:40:19.886 | 2026-01-09 20:40:19.886 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:19.886 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:19.886 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:19.889 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:19.890 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:19.890 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:19.895 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:19.895 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:19.895 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:19.895 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:19.915 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:19.915 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:19.915 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:19.915 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:19.915 | Rithmic Direct - DTC | Failed connections: 24 2026-01-09 20:40:19.915 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:19.915 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:19.920 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:19.921 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:19.921 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:19.921 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:19.922 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:19.926 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:19.926 | DTC Client socket (1) | Closed. 2026-01-09 20:40:23.914 | 2026-01-09 20:40:23.914 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:23.914 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:23.914 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:23.920 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:23.921 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:23.921 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:23.927 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:23.927 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:23.927 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:23.927 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:23.946 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:23.946 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:23.946 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:23.946 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:23.946 | Rithmic Direct - DTC | Failed connections: 25 2026-01-09 20:40:23.946 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:23.946 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:23.961 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:23.962 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:23.962 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:23.963 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:23.963 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:23.965 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:23.965 | DTC Client socket (1) | Closed. 2026-01-09 20:40:27.965 | 2026-01-09 20:40:27.965 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:27.965 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:27.965 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:27.969 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:27.970 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:27.970 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:27.976 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:27.976 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:27.976 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:27.976 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:28.007 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:28.007 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:28.007 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:28.007 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:28.007 | Rithmic Direct - DTC | Failed connections: 26 2026-01-09 20:40:28.007 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:28.007 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:28.027 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:28.029 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:28.029 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:28.029 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:28.029 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:28.034 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:28.035 | DTC Client socket (1) | Closed. 2026-01-09 20:40:32.023 | 2026-01-09 20:40:32.023 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:32.024 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:32.024 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:32.025 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:32.026 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:32.026 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:32.031 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:32.031 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:32.031 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:32.031 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:32.055 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:32.055 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:32.055 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:32.055 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:32.055 | Rithmic Direct - DTC | Failed connections: 27 2026-01-09 20:40:32.055 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:32.055 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:32.071 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:32.072 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:32.072 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:32.072 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:32.072 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:32.076 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:32.079 | DTC Client socket (1) | Closed. 2026-01-09 20:40:36.072 | 2026-01-09 20:40:36.072 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:36.072 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:36.072 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:36.074 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:36.074 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:36.074 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:36.082 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:36.082 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:36.082 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:36.082 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:36.096 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:36.096 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:36.096 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:36.096 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:36.096 | Rithmic Direct - DTC | Failed connections: 28 2026-01-09 20:40:36.096 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:36.096 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:36.104 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:36.104 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:36.104 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:36.104 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:36.104 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:36.107 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:36.107 | DTC Client socket (1) | Closed. 2026-01-09 20:40:40.107 | 2026-01-09 20:40:40.108 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:40.108 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:40.108 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:40.112 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:40.112 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:40.112 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:40.115 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:40.115 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:40.116 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:40.116 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:40.134 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:40.134 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:40.135 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:40.135 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:40.135 | Rithmic Direct - DTC | Failed connections: 29 2026-01-09 20:40:40.135 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:40.135 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:40.138 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:40.138 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:40.138 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:40.138 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:40.138 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:40.141 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:40.141 | DTC Client socket (1) | Closed. 2026-01-09 20:40:44.134 | 2026-01-09 20:40:44.134 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:44.134 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:44.134 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:44.135 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:44.135 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:44.135 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:44.138 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:44.138 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:44.138 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:44.138 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:44.153 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:44.153 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:44.153 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:44.153 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:44.153 | Rithmic Direct - DTC | Failed connections: 30 2026-01-09 20:40:44.153 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:44.153 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:44.166 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:44.166 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:44.166 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:44.166 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:44.166 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:44.169 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:44.169 | DTC Client socket (1) | Closed. 2026-01-09 20:40:48.161 | 2026-01-09 20:40:48.162 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:48.162 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:48.162 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:48.167 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:48.169 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:48.169 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:48.177 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:48.177 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:48.177 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:48.177 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:48.212 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:48.212 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:48.212 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:48.212 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:48.212 | Rithmic Direct - DTC | Failed connections: 31 2026-01-09 20:40:48.212 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:48.212 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:48.225 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:48.225 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:48.225 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:48.225 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:48.225 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:48.230 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:48.230 | DTC Client socket (1) | Closed. 2026-01-09 20:40:52.228 | 2026-01-09 20:40:52.229 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:52.229 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:52.229 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:52.229 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:52.230 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:52.230 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:52.232 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:52.232 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:52.232 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:52.232 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:52.246 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:52.246 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:52.246 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:52.246 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:52.246 | Rithmic Direct - DTC | Failed connections: 32 2026-01-09 20:40:52.246 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:52.246 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:52.260 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:52.260 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:52.260 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:52.260 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:52.260 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:52.263 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:52.263 | DTC Client socket (1) | Closed. 2026-01-09 20:40:56.257 | 2026-01-09 20:40:56.258 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:40:56.258 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:40:56.258 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:40:56.261 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:40:56.261 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:40:56.261 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:40:56.264 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:40:56.264 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:40:56.264 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:40:56.264 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:40:56.278 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:40:56.278 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:40:56.278 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:40:56.278 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:40:56.278 | Rithmic Direct - DTC | Failed connections: 33 2026-01-09 20:40:56.278 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:40:56.278 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:56.289 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:40:56.290 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:40:56.290 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:40:56.290 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:40:56.290 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:40:56.292 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:40:56.293 | DTC Client socket (1) | Closed. 2026-01-09 20:41:00.292 | 2026-01-09 20:41:00.293 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:00.293 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:00.293 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:00.295 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:00.296 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:00.296 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:00.332 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:00.332 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:00.333 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:00.333 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:00.517 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:00.518 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:00.518 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:00.518 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:00.518 | Rithmic Direct - DTC | Failed connections: 34 2026-01-09 20:41:00.518 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:00.518 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:00.528 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:00.530 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:00.531 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:00.531 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:00.532 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:00.548 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:00.548 | DTC Client socket (1) | Closed. 2026-01-09 20:41:04.531 | 2026-01-09 20:41:04.531 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:04.531 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:04.531 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:04.534 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:04.537 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:04.537 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:04.555 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:04.555 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:04.555 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:04.555 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:04.570 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:04.570 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:04.570 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:04.570 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:04.570 | Rithmic Direct - DTC | Failed connections: 35 2026-01-09 20:41:04.570 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:04.570 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:04.576 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:04.576 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:04.576 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:04.576 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:04.576 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:04.579 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:04.579 | DTC Client socket (1) | Closed. 2026-01-09 20:41:08.573 | 2026-01-09 20:41:08.574 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:08.574 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:08.574 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:08.577 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:08.578 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:08.578 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:08.583 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:08.583 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:08.583 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:08.583 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:08.609 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:08.609 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:08.609 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:08.609 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:08.609 | Rithmic Direct - DTC | Failed connections: 36 2026-01-09 20:41:08.609 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:08.609 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:08.622 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:08.624 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:08.624 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:08.624 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:08.624 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:08.633 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:08.633 | DTC Client socket (1) | Closed. 2026-01-09 20:41:12.617 | 2026-01-09 20:41:12.617 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:12.618 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:12.618 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:12.625 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:12.625 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:12.625 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:12.634 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:12.634 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:12.634 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:12.634 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:12.663 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:12.663 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:12.663 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:12.663 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:12.663 | Rithmic Direct - DTC | Failed connections: 37 2026-01-09 20:41:12.663 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:12.663 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:12.680 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:12.680 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:12.681 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:12.681 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:12.681 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:12.683 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:12.683 | DTC Client socket (1) | Closed. 2026-01-09 20:41:16.681 | 2026-01-09 20:41:16.681 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:16.681 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:16.681 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:16.685 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:16.686 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:16.686 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:16.691 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:16.691 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:16.691 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:16.691 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:16.723 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:16.723 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:16.723 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:16.723 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:16.723 | Rithmic Direct - DTC | Failed connections: 38 2026-01-09 20:41:16.723 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:16.723 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:16.744 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:16.746 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:16.746 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:16.746 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:16.748 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:16.760 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:16.760 | DTC Client socket (1) | Closed. 2026-01-09 20:41:20.745 | 2026-01-09 20:41:20.745 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:20.745 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:20.745 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:20.750 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:20.752 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:20.752 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:20.759 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:20.759 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:20.759 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:20.759 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:20.785 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:20.785 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:20.785 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:20.785 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:20.785 | Rithmic Direct - DTC | Failed connections: 39 2026-01-09 20:41:20.785 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:20.785 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:20.800 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:20.803 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:20.803 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:20.803 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:20.806 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:20.819 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:20.820 | DTC Client socket (1) | Closed. 2026-01-09 20:41:24.806 | 2026-01-09 20:41:24.807 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:24.807 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:24.807 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:24.807 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:24.807 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:24.807 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:24.810 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:24.810 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:24.810 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:24.810 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:24.823 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:24.823 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:24.823 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:24.823 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:24.823 | Rithmic Direct - DTC | Failed connections: 40 2026-01-09 20:41:24.823 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:24.823 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:24.838 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:24.838 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:24.838 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:24.838 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:24.838 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:24.841 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:24.841 | DTC Client socket (1) | Closed. 2026-01-09 20:41:28.832 | 2026-01-09 20:41:28.833 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:28.833 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:28.833 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:28.836 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:28.836 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:28.836 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:28.838 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:28.838 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:28.838 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:28.838 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:28.851 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:28.851 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:28.851 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:28.851 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:28.851 | Rithmic Direct - DTC | Failed connections: 41 2026-01-09 20:41:28.851 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:28.851 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:28.864 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:28.865 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:28.865 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:28.865 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:28.865 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:28.868 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:28.868 | DTC Client socket (1) | Closed. 2026-01-09 20:41:32.860 | 2026-01-09 20:41:32.860 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:32.860 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:32.860 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:32.861 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:32.861 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:32.861 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:32.864 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:32.864 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:32.864 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:32.864 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:32.878 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:32.878 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:32.878 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:32.878 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:32.878 | Rithmic Direct - DTC | Failed connections: 42 2026-01-09 20:41:32.878 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:32.878 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:32.892 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:32.892 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:32.892 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:32.892 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:32.892 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:32.895 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:32.895 | DTC Client socket (1) | Closed. 2026-01-09 20:41:36.904 | 2026-01-09 20:41:36.904 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Non-Aggregated 2026-01-09 20:41:36.904 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503 2026-01-09 20:41:36.904 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503 2026-01-09 20:41:36.909 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-09 20:41:36.910 | DTC Client socket (1) | New receive buffer size: 0 2026-01-09 20:41:36.910 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-09 20:41:36.914 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-09 20:41:36.914 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-09 20:41:36.914 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-09 20:41:36.914 | Rithmic Direct - DTC | Sending logon request message. 2026-01-09 20:41:36.944 | Rithmic Direct - DTC | Received logon response. 2026-01-09 20:41:36.944 | Rithmic Direct - DTC | Server Name: . 2026-01-09 20:41:36.944 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-09 20:41:36.944 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-01-09 20:41:36.944 | Rithmic Direct - DTC | Failed connections: 43 2026-01-09 20:41:36.944 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-09 20:41:36.944 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:36.952 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-09 20:41:36.952 | DTC Client socket (1) | CloseSocket call. 2026-01-09 20:41:36.952 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-09 20:41:36.952 | Rithmic Direct - DTC | Disconnected. 2026-01-09 20:41:36.952 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-09 20:41:36.955 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-09 20:41:36.955 | DTC Client socket (1) | Closed. |
| [2026-01-09 22:47:04] |
| John - SC Support - Posts: 48342 |
It helps if you tell us why you are sending us your Message Log. Fortunately, it was fairly obvious in this case. You are getting the following: Rithmic Direct - DTC | Logon error received from server: permission denied
Refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
