Date/Time: Wed, 25 Nov 2026 22:21:07 +0000
v2859 - SOME CHART STUDIES NOT RENDERING / NOT SET TO 'HIDDEN'
View Count: 449
[2026-01-09 17:12:04]
LongShortz - Posts: 53
I upgraded my instance to 2859 this morning and now there are select studies that will no longer render on my charts even though they are not set to hidden. I've attempted to hide/unhide, reload the STDYCOLLCT, restart the software, reboot PC.... all to no avail. Need some assistance.
[2026-01-09 17:21:48]
All of my VWAP studies are failing to render. I also have a 3rd party VWAP and that one works. So only the SC VWAP study seems to be broken for me right now. I tried to remove one and re-add it but that did not resolve the issue either.
[2026-01-09 18:47:56]
We are not seeing any issue with the VWAP study on version 2859.
Check to make sure the drawing of the VWAP is not somewhere above/below the current bars and therefore just not immediately visible. Compress your scale to view a wider range and see if it is actually there, just not where you were expecting.
If you are still having a problem with this, then get us a chart that shows this issue by following these instructions:
[2026-01-09 19:51:58]
Okay so I rolled back to the previous version and everything works great. I saved everything, took a backup, and upgraded back to 2859. Problem recurred. I am going to upload a file to you guys for troubleshooting. Thx.
[2026-01-09 20:05:35]
Here is the file.
Private File
[2026-01-09 20:33:46]
Sierra_Chart Engineering - Posts: 25484
We are testing this.
[2026-01-09 20:47:14]
This will be solved in the next release coming out today or tomorrow. For now roll back to the prior version with Help >> Install Previous Version.
