Date/Time: Wed, 25 Nov 2026 22:21:06 +0000
BUG(s) in Current Traded Bid-Ask and Diagonal Bid/Ask DOM Columns
View Count: 628
| [2026-01-09 12:35:48] |
| TopGunTrader - Posts: 313 |
Hi, First a MILLION thank you's for finally putting this in its ESSENTIAL for trading and I pay $50+ a month to use Jigsaw for these features and their momentum tails. I have noticed some odd behaviors. 1) Biggest is no matter if value is + or - its always RED so showing the histogram is not something a trader can use right now as positive numbers are RED this has to be fixed or its somewhat useless. 2) Diagonal Delta values not in my humble opinion correct. It appears it is ONLY calculated GOING UP and this is not how it should be calculated. Case in point in green box in picture shown at 25731 price area. The MIDDLE 5 diagonal value is because 7 is greater than 2 and is 5 greater HOWEVER diagonal delta is ALSO calculated GOING DOWN and the 3 ask value is 6 less than 9 bid value in the middle and -6 is bigger in absolute terms than the 5 so it should show -6 there. I realize this is complicated and there are many ways to do it if it WERE ME I'd see where price is NOW and if above 25731 I'd show the 5 positive number and if price is UNDER 25731 that should display a -6 as the 9 on bid is 6 more than 3 on ask above. That for scalpers is the PERFECT METHOD for calculating this. It can't just be start low and go up needs CONTEXT of where price is NOW in relation to these numbers. 3) Need options in Chart - Graphics Settings Chart to have COLORS for histogram it can't always be red even for positive numbers. Absolutely essential. Maybe this is the goal and already on list to be done but is essential for me this is unusable with the histogram right now will trick me into thinking market is bearish and I'd lose money for sure with this. 4) When resetting current bid/ask the TOTALS don't get reset maybe this is on development list or maybe its a bug nobody noticed this has to be fixed or its not as useful as it should be. 5) Maybe have Keyboard Short for both diagonal and deltas to be reset! I might want to keep the deltas but reset the diagonal one at times and of course resetting current bid/ask resets BOTH is how I'd have it work. I take 30-50 trades a day and Jigsaw's DOM is a major part of my system at key areas. It has many bugs and I'd love to get rid of it! When this is perfected I probably will as I'm working with a guy to create the momentum tails and I'd have everything in your far superior product I absolutely need. |
| [2026-01-09 12:42:46] |
Another good example of diagonal delta count being off shows -186 as it doesn't reset vs if I typed correct numbers into excel right approx +54.
| [2026-01-09 16:32:39] |
| Sierra_Chart Engineering - Posts: 25484 |
Thank you. We will go through all of this.
| [2026-01-12 12:58:52] |
Congrats on fixing the current traded delta and diagonal delta on current traded RESET that now works. I couldn't find where to change colors maybe not in yet? I also notice the diagonal delta is showing wrong values. I've been thinking about my last comment on that and really the only way to do diagonal delta correctly is show the HIGHEST value. So for instance A B 5 x 10 15 x 6 -5 3 3 x 5 So in this case you could show the 3 going up or -5 going down need to show the max so -5 OPTIMAL Diagonal Delta 10 x 5 SHOULD BE BLANK 5<35 and there's no print above if 5 prints on ask then show -5 35 x 15 -30 (5-35 in absolute terms bigger than 15-1) 1 x 10 3 7 x 3 SHOULD BE BLANK as the 16 on bid below bigger in absolute terms 16 x 5 -13 (3-16 in absolute terms bigger than 5-4) 4 x 17 SHOULD BE BLANK AS 4<5 AND there hasn't been a bid print below to diagonally compare the 17 with! Some and often many spaces need to be blank when logic dictates and the count will be far more useful with real diagonal compares! |
| [2026-01-12 17:47:29] |
We still have not gone through all of the items, from the first post.
