Date/Time: Wed, 25 Nov 2026 22:21:04 +0000
MIn max each minute
View Count: 466
[2026-01-08 19:49:11]
User244327 - Posts: 19
Hi folks,
I would appreciate some help with finding the min and max values for each minute... I can get the min max for between certain times, but not for every minute. Maybe it is possible within the Spreadsheet, but I don't know. If someone could recommend a method for finding these values, I would be very appreciative.
Many thanks,
Peter
[2026-01-08 23:34:34]
Min and Max of what?
[2026-01-09 07:03:01]
sorry, I thought I was clear.... min and max price value for every minute
[2026-01-09 16:13:47]
You would have to have a 1 minute chart in order to get this data.
What are you wanting to do with it? How do you want to view it? What exactly are you trying to do?
[2026-01-09 17:46:30]
I have various time frame chart .. ranging from x second, to 1 minute to Daily Charts .....I'm looking to do a bit of analysis on when the High and low of the 1 minute bar are most likely to occur. Pretty simple.... but I don't know how to code for getting this min/max price data for every minute. Any help would be appreciated.
[2026-01-09 18:55:25]
To get the High and Low of every 1 minute bar, start with a 1 minute chart and add the "Period OHLC - Variable Period" study to the chart and set the following Inputs:
- Time Period Type: Minutes
- Time Period Length: 1
- Use Current Period: Yes
Then on the Subgraphs tab for that study set the "Draw Style" for the "Open" and "Close" subgraphs to be "Ignore".
This will give you the High and Low at every 1 minute interval in the "High" and "Low" subgraphs for that study.
