Date/Time: Wed, 25 Nov 2026 22:21:05 +0000
Spreadsheet Issues in v2858
View Count: 331
[2026-01-08 16:15:16]
User247273 - Posts: 51
I know you've already posted about some spreadsheet and shortcut key issues in recent releases but I can't' find these specific ones mentioned anywhere.
1. Dropdown list for worksheets is not functional. If I click the list box arrow to see the list of sheets and pick one, I do see the list field highlight, but it is otherwise unresponsive. This issue existed in many previous releases but has been intermittent and I figured it might be due to something on my end. I'm just mentioning it in case you have other users reporting the same problem.
2. I used to be able to edit the value in a spreadsheet cell by hitting Enter, typing the value, and hitting Enter again. Now, I can hit Enter and change the value but the only way to execute the change is to physically click the new "OK" button with my mouse. I hope this is some sort of intermediate stage of development. Please provide a way to quickly edit spreadsheet cells - ideally the old way, but even just being able to Tab over to the OK button and hit Enter would be fine as well. It is INCREDIBLY inefficient to have to move hands off the keyboard and use the mouse for something so simple. Editing or setting up spreadsheets will take a ton more time if the current implementation stays in place.
3. The attached image shows the keyboard shortcuts I have assigned to various spreadsheet operations. I have confirmed those shortcuts are still assigned properly; however, nothing happens when I use them. I also have CTRL+ALT+SHIFT+F7 assigned to File>>Close Chartbook. That shortcut has always worked form within a spreadsheet window as well as anywhere else in the current chartbook. It no longer responds when I am in the spreadsheet. It works as expected if I click on a chart in the chartbook and then use the shortcut to close the chartbook.
imageScreenshot 2026-01-08 100316.png / V - Attached On 2026-01-08 16:05:38 UTC - Size: 66.48 KB - 146 views
[2026-01-08 17:00:06]
Sierra_Chart Engineering - Posts: 25484
We are aware of some of these issues, and they will be resolved, in the next release. We will also check on 3.
