Date/Time: Wed, 25 Nov 2026 22:26:20 +0000
User Contributed Studies.Dll on SierraChart ARM64
View Count: 987
| [2026-01-08 12:57:47] |
| User973477 - Posts: 5 |
Hi, I'm trying to get ECI VWAP working on SierraChart ARM64. However I got the error message in the log below. I've tried downloading prerelease and "Install Optional Components" however no success. The UserContributedStudies is not showing up under the "customs studies" either. Message Log: 2026-01-08 13:51:47.973 | Found DLL: C:\Mac\Home\Documents\Windows\SierraChart2808\Data\UserContributedStudies.dll 2026-01-08 13:51:47.981 | UserContributedStudies.dll loading error. Windows error code 193: %1 is not a valid Win32 application. 2026-01-08 13:51:47.986 | UserContributedStudies_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application. 2026-01-08 13:51:47.986 | InternalVersionNumberToFileNameMap is empty for UserContributedStudies 2026-01-08 13:51:47.986 | Closest match search for: C:\Mac\Home\Documents\Windows\SierraChart2808\Data\UserContributedStudies.dll returned empty result. * |
| [2026-01-08 13:13:30] |
| Chris32 - Posts: 81 |
Just use the built in VWAP, works fine
| [2026-01-08 23:59:29] |
| Sierra_Chart Engineering - Posts: 25484 |
You need to update Sierra Chart to the latest release. That version includes ECI VWAP in the ARM64 version. You will find it in Analysis >> Studies >> Add Custom Study >> Sierra Chart Custom Studies and Examples. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-08 23:59:44
| [2026-01-11 12:31:41] |
I've updated to v2858. The Usercontributedstudies worked once directly after the update. After a restart it stopped working again, getting the following result in the message log. 2026-01-11 13:27:54.981 | Found DLL: C:\Mac\Home\Documents\Windows\SierraChart2808\Data\UserContributedStudies.dll 2026-01-11 13:27:54.987 | UserContributedStudies.dll loading error. Windows error code 193: %1 is not a valid Win32 application. 2026-01-11 13:27:54.993 | UserContributedStudies_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application. 2026-01-11 13:27:54.993 | InternalVersionNumberToFileNameMap is empty for UserContributedStudies 2026-01-11 13:27:54.993 | Closest match search for: C:\Mac\Home\Documents\Windows\SierraChart2808\Data\UserContributedStudies.dll returned empty result. * |
| [2026-01-13 00:44:54] |
The location of those particular VWAP studies is different: You will find them in Analysis >> Studies >> Add Custom Study >> Sierra Chart Custom Studies and Examples. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-15 09:19:07] |
I understand the workaround for the ECIVWAP and got that working but how do I get other studies working which are included in the "UserContributedStudies" as it is not loading correctly. Please refer to the message log below: 2026-01-11 13:27:54.981 | Found DLL: C:\Mac\Home\Documents\Windows\SierraChart2808\Data\UserContributedStudies.dll 2026-01-11 13:27:54.987 | UserContributedStudies.dll loading error. Windows error code 193: %1 is not a valid Win32 application. 2026-01-11 13:27:54.993 | UserContributedStudies_64.dll loading error. Windows error code 193: %1 is not a valid Win32 application. 2026-01-11 13:27:54.993 | InternalVersionNumberToFileNameMap is empty for UserContributedStudies 2026-01-11 13:27:54.993 | Closest match search for: C:\Mac\Home\Documents\Windows\SierraChart2808\Data\UserContributedStudies.dll returned empty result. * I've got the latest version and tried downloading prerelease. |
| [2026-01-16 18:53:01] |
What other studies are you using in User Contributed Studies?
