Date/Time: Wed, 25 Nov 2026 22:20:48 +0000
current price
View Count: 372
[2026-01-07 19:01:10]
Pavel2 - Posts: 22
Can't see the current price on the right side of chart and can't figure out why.
Thank you
[2026-01-07 19:35:36]
Refer to the following Graphics Setting and see if it is disabled for some reason:
Graphics Settings: Last Trade Price Box
Also make sure the color of the above and the 2 items below it are set so you can view the box.
Keep in mind there are both Global Graphics settings and Chart Specific Graphics settings, so make sure you are checking the appropriate location for this item for your specific chart. Refer to the following:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
If the above does not resolve the issue, then we would need to see an image of your chart by following these instructions:
