Date/Time: Wed, 25 Nov 2026 22:20:43 +0000
How to change the Extend chart DOM accross entire chart default keys
View Count: 411
[2026-01-07 17:41:36]
shaanbullet - Posts: 4
How do I change the default DOM settings that extend the DOM across the entire chart?
I find myself hitting the ctrl + left click button a lot by mistake, which accidently gets me into LONG positions.
So how do I change ctrl (buy) to another key, and same thing for the Shift (Sell) key.
[2026-01-07 19:28:07]
There is no option to change the key that is used to actually "extend the DOM" across the chart. That is, it is tied to CTRL+click and SHIFT+click.
The option available, however is to change the setting that allows this option. Although there is not a keyboard shortcut to turn this off/on. Refer to the following:
Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu)
We have noted feature requests for the following:
- Allow user to change the keys used to extend the DOM across the entire chart
- Have a keyboard shortcut/Control Bar button to toggle on/off the option for "Extend Chart DOM Across Entire Chart When Using Ctrl/Shift"
