Date/Time: Wed, 25 Nov 2026 22:21:04 +0000
[Programming Help] - ACSIL Replay Control
View Count: 659
[2026-01-06 14:22:38]
User213910 - Posts: 28
Hi Sierra Chart Team,
Happy New Year!
I have a question regarding Replay Mode in Sierra Chart:
Is it possible to control the Replay via ACSIL?
Specifically, I would like to:
•Start and reset the Replay
•Potentially control the replay speed
•(Adjust other settings available in the Replay Control Panel programmatically)
Is any of this currently supported through ACSIL, or are there recommended alternatives?
If not, can you add it?
Thank you in advance for your support.
Best regards
[2026-01-07 16:48:07]
Tony - Posts: 738
There should be multiple functions/variables related to chart replay,
I would go function page:
ACSIL Interface Members - Functions
and search "replay"
[2026-01-10 13:28:48]
You are right. Thank You.
