Date/Time: Wed, 25 Nov 2026 22:08:28 +0000
Market Depth Historical Chart no matching DOM
View Count: 456
[2026-01-06 14:18:16]
User656492 - Posts: 160
Hi. I see different values when looking at Market Depth Historical Graph vs DOM in ES, NQ, RTH.
Specifically, I see higher numbers in the DOM than in Market Depth.
Seeing higher numbers in market depth would make sense, but the opposite confuses me.
I'm sure there's a setting somewhere that needs attention ... ?
Thank you!
[2026-01-06 16:21:23]
In order to have the Market Depth Historical Graph displaying the same data that is in the DOM, you need to have the following Input set to "Yes":
Market Depth Historical Graph: Use Last Quantity Instead Of Max Quantity For Bars
And if you are extending the last depth beyond the last bar and you are looking at those values, then you need to set the following to "Last Depth":
Market Depth Historical Graph: Depth Quantity Type to Display After Last Bar
Also, keep in mind that if you have the Input for "Extend Last Known Depth", then you may be looking at outdated information in the Market Depth Historical Graph that is being continued forward and therefore will not align to the DOM. Refer to the following:
Market Depth Historical Graph: Extend Last Known Depth
And finally, be sure to select "File >> Disconnect" when comparing the values in the DOM to the Market Depth Historical Graph. This ensures that the data is properly updated at the same time, so you will be able to correlate the data. Otherwise, you could see discrepancies as the DOM updates faster than the Market Depth Historical Graph.
