Date/Time: Wed, 25 Nov 2026 22:26:26 +0000
Window title bar color and font
View Count: 1329
| [2026-01-06 01:28:58] |
| User472677 - Posts: 400 |
You say, 'Title bar colors, and sizes, are now are now initially configured by default according to your operating system settings. After installing this version you can change them to whatever you want thereafter. If you have already made changes in previous versions, your existing changes will remain.' How to change windows title bar color and font? |
| [2026-01-06 03:19:06] |
| User719512 - Posts: 548 |
This might start you in the right direction Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off | Post: 431980 |
| [2026-01-06 15:18:23] |
Refer to the following Graphics Setting and the 5 entries below it: Graphics Settings: Window Title Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-08 21:24:46] |
Hi I followed the instructions. But making changes to inactive title bar text color does not change the color determined by windows. Is there additional setting to ask windows to relinquish control? |
| [2026-01-08 23:06:29] |
| Sierra_Chart Engineering - Posts: 25484 |
Therefore, you must be trying to change the color of a title bar which is controlled by the operating system. You are only able to change the color of title bars within Sierra Chart of MDI child windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-08 23:06:41
| [2026-01-09 06:08:52] |
I thought in the new version I can change font text color on detached windows title bars from the graphic settings within sc. Is this not right? On a separate note, when I change the font text color for windows title bar from windows it changes for apps other than sc but it does not change for sc. I have tried on 2 different computers. Same results. At present the font text color on sc detached windows is light Grey on white. It is not easily readable. |
| [2026-01-09 16:12:36] |
This is not right. Detached windows are still managed by the Operating System. So those window colors are set by the OS. Windows that are displayed within the Sierra Chart main graphics area (attached windows) are the ones where you can change the colors and fonts and the other items that have been made available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-13 01:55:01] |
I can edit windows registry to change the windows title bar text font color. It works for every app I use with the exception of sc. In sc inactive floating windows title bar text color is light Grey on greyish background. It is no problem on a laptop but on a large monitor with numerous charts, text is not readable. Please help to change windows title bar text color. |
| [2026-01-13 20:33:01] |
Please help
| [2026-01-13 20:44:34] |
Are you referring to title bars for detached windows or attached windows? For attached windows, this is now controlled through the settings in Sierra Chart. Refer to the following and the 3 items below it: Graphics Settings: Window Title Bar For detached windows, these are controlled through the Operating System. If editing the Registry is not working, then this is not something we can help with. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-15 01:54:06] |
Thank you John. Can you help me understand why changing registry works for every app I use but not Sierra? If you can help me understand this, I can attempt to find a solution.
| [2026-01-15 15:56:21] |
We have no idea. And this is not something we can spend time digging into to figure out why. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
