Date/Time: Wed, 25 Nov 2026 16:34:48 +0000
Quote spreadsheet problem
View Count: 1439
| [2014-10-20 15:14:06] |
| jonno - Posts: 14 |
Hi I'm running latest current version of SC. I don't seem to be able to get the quote header when I type in ##HD. The quotes come up ok but no header at the top of the column. Any suggestions. Regards John |
| [2014-10-20 15:56:13] |
This is something we need to work on adding support for with the New Spreadsheets.
| [2014-11-14 20:55:25] |
| rhovega - Posts: 279 |
Same issue here - would like to know once functional. Thanks.
| [2014-11-15 04:48:46] |
This is now supported in the New Spreadsheets by enabling Spreadsheet >> Quote Spreadsheet.
