Date/Time: Wed, 25 Nov 2026 22:08:25 +0000
moving from one working pc to the other one - files don't look the same
View Count: 298
[2026-01-05 20:57:44]
User938576 - Posts: 3
i was reacntly moving from one working pc to the other one and i moved all of my chart files and when i opend them on my new pc the chart files didnt look the same at all and i didnt have any of my indicatores
[2026-01-05 22:47:12]
With regards to the Indicators, if you are using custom studies, then you need to ensure you moved the files from the old computer to the new one as well. These files would have an extension of .dll and would be located in the "Data" folder under the main Sierra Chart installation folder.
You should have all the Sierra Chart built-in studies available. If you do not, then do an update of the software (even to the same version) and see if that resolves the issue.
With regards to the "chart files didnt look the same at all", we would need more information. But we wonder if this is related to the indicators issue you are referencing.
