Date/Time: Wed, 25 Nov 2026 22:08:18 +0000
My charts will not reset to 2026
View Count: 669
| [2026-01-05 17:13:43] |
| trader88 - Posts: 35 |
All my data is stale and shows 2025-12-19. It seems I am unable to reset it and see current data flow.
| [2026-01-05 17:32:03] |
Is there not a way to update all symbols that I reference from overlayed charts automatically?
| [2026-01-05 17:47:19] |
OK, no worries, I got this. I just wanted to know if there is a way to update symbols on the chart that has overlays from other charts. I did this manually going to each chart and updated a symbol. I would think, we could have a way to do it with just one click on main chart.
| [2026-01-05 19:37:47] |
When you rollover a chart, the system automatically updates all charts that were on that symbol to the new one. You do need to specifically rollover each symbol. There is an option for "Chart >> Chart Settings >> Automatically Rollover Futures Symbol", but as you will see in the documentation, this is not recommended. Refer to the following: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
