Date/Time: Wed, 25 Nov 2026 22:08:02 +0000
apex rithmic candles not updating
View Count: 282
| [2026-01-05 15:53:47] |
| stiasny - Posts: 25 |
HI, I have had several times where price was seen updating on the vertical axis, but candles were not forming. Most of the time the issue went away quick, or on restart. now its been 1 hour and half since the bars are not updating. I also see that scid file is not updating at all which means that the tick data is not being saved Cheers Date Time Of Last Edit: 2026-01-05 15:55:20
| [2026-01-05 18:42:01] |
You are setup to get the data from Rithmic, and this generally means there is an issue with the Rithmic data. Please get us your Message Log by following these instructions and we will take a look and see if there is anything specific showing in the log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
