Date/Time: Wed, 25 Nov 2026 22:08:29 +0000
[Programming Help] - CSV file import for daily trend line
View Count: 391
[2026-01-05 01:18:20]
adamja - Posts: 1
Hi there,
l would like know if l can download this CSV file into sierras chart for daily trend line and some other simple study, l will attached the excel file with this email please let me know if it's doable
so I don't have to draw the support and resistance lines manually for stocks and indexes daily, the attached file is from a data provider that I subscribed for their service,
thank you
Private File
[2026-01-05 16:34:18]
There is not a direct way to import data to create a line, or other markup, on a chart.
The only way to do this would be to create a custom study. Refer to the following:
Advanced Custom Study Interface and Language (ACSIL)
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2026-01-05 17:28:21]
User584084 - Posts: 348
There 2 ways.
1) https://www.youtube.com/watch?v=0R73EQxfeGY
2) https://www.simplesystemtrading.com/autolevels/
