Date/Time: Wed, 25 Nov 2026 22:08:25 +0000
Main Window Menu Bar Color
View Count: 690
[2026-01-04 20:21:53]
User247273 - Posts: 51
I've updated to version 2789 Revision 53991
I know there have recently been changes to how windows are handled which allow control of Title Bar color, etc. There still seems to be no way to control the color of the menu bar (specifically the menu bar in the Main Window) from within Sierra. Am I correct on that? If so, is that likely to become available at some point as you continue development around how Sierra handles windows?
[2026-01-04 21:54:15]
Yes you are correct about that. The main title bar color is all controlled by the operating system.
At some point, the title bar of the main window will be controllable but not now. Only what are called the MDI child windows, the chart windows within the main window, can you control the title bar colors and border.
[2026-01-05 16:17:13]
To be able to change the colors of the MDI windows, you need to be on the current release (v 2852). The version you are on (v 2789) does not have the changes to those windows.
