Date/Time: Wed, 25 Nov 2026 22:08:23 +0000
Replay Update Interval In Milliseconds does not seem to work and is not documented
View Count: 562
| [2026-01-04 19:29:00] |
| User719512 - Posts: 548 |
Replay Update Interval In Milliseconds does not seem to work and is not documented Expected under Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Easiest repro is showing a DOM during replay and set Chart Update Interval in Milliseconds to low value like 250 Replay Update Interval In Milliseconds to high value like 2000 Start replay DOM will update frequently Set Chart Update Interval in Milliseconds to 2000 DOM will update every 2 seconds which should have been controlled by Replay Update Interval In Milliseconds NIT: the word "in" is capitalized for the replay setting, and lowercase elsewhere in that screen (similar to "to and as") |
| [2026-01-04 23:48:30] |
| Sierra_Chart Engineering - Posts: 25483 |
Here is the documentation: Chart Settings: Replay Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) All of the questions are answered there. We will fix this: NIT: the word "in" is capitalized for the replay setting, and lowercase elsewhere in that screen (similar to "to and as") Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-04 23:51:09
