Date/Time: Wed, 25 Nov 2026 22:08:27 +0000
[Programming Help] - Programmatically generate charts with specific study and series type
View Count: 530
[2026-01-04 17:31:46]
User179576 - Posts: 3
I would like to automatically generate charts from a list of symbols with parameters that change and make them a specific type as well as add studies with ACSIL.
So far I have been able to generate them correctly. However I have not been able to change the bar type to candlestick. And I have not been able to add studies to them either.
Is there any way to do so?
s_ACSOpenChartParameters VolumeChartParams;
VolumeChartParams.PriorChartNumber = 0;
VolumeChartParams.ChartDataType = INTRADAY_DATA;
VolumeChartParams.Symbol = CurrentSymbol;
VolumeChartParams.DaysToLoad = 10;
VolumeChartParams.LoadWeekendData = 0;
VolumeChartParams.IntradayBarPeriodType = static_cast<IntradayBarPeriodTypeEnum>(1);
VolumeChartParams.IntradayBarPeriodLength = (int)CurrentEffectiveVolume;
int VolumeChartNumber = sc.OpenChartOrGetChartReference(VolumeChartParams);
if (VolumeChartNumber > 0)
VolumeChartNumbers.push_back(VolumeChartNumber);
LogMsg.Format("Created volume chart #%d for %s (Volume bars: %.0f)",
VolumeChartNumber, CurrentSymbol.GetChars(), CurrentEffectiveVolume);
sc.AddMessageToLog(LogMsg, 0);
sc.RecalculateChart(VolumeChartNumber);
Thank you.
[2026-01-04 19:33:56]
ForgivingComputers.com - Posts: 1256
There does not appear a way to set the new chart to candlesticks in ACSIL.
However, you can change the default for new charts to candlesticks here: Chart Settings: Save Days to Load, Intraday Bar Period, Graph Draw Type as Default (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
[2026-01-04 19:59:56]
Thank you that helped. My last step would be to automatically add a study. For now I think the only solution might be to program the study into the code directly instead of using a pre-made study.
[2026-01-04 22:33:10]
ACSIL Interface Members - Functions: sc.AddStudyToChart()
[2026-01-05 07:26:22]
That works thank you!
