Date/Time: Wed, 25 Nov 2026 22:08:30 +0000
Custom Control Bar Buttom For Chart Replay Control Panel?
View Count: 373
| [2026-01-03 22:05:24] |
| User708541 - Posts: 215 |
I can't figure out how to get a button for Chart Replay Control Panel to work. I'm currently on version 2851. I've tried all the available options under 'Chart-General' Is this possible or am I missing something? |
| [2026-01-05 15:53:23] |
The Control Bar button to open the Chart Replay window is named "Replay Chart" and is under the "Chart - General" section.
| [2026-01-05 17:20:49] |
As I mentioned in my first post, I tried all the choices Under "Chart-General" There are 4 "Replay" choices. None of them say only " Replay Chart". Choices are: Replay Chart Play/Pause Replay Chart Stop Replay Chart Jump Backward Replay Chart Jump Forward And Reset Replay Control Panel Window I've tried all of these and none bring up the replay control panel. |
| [2026-01-05 19:05:40] |
If you do not see the option for "Replay Chart" then this means that it is already added to the Control Bar that you are modifying.
