Date/Time: Thu, 12 Nov 2026 21:39:49 +0000
Line with quick alert
View Count: 1817
[2014-10-20 08:22:56]
User17064 - Posts: 70
Hi SC support,
I know how to set a alert for one price.What I want to ask is is there any quick way to set the alert for the price cross the line. For example, currently, I need to firstly put one line then right click the line then popup the menu, then select the "Alert" then set the condition for cross the price. A little bit complicated, is there any fast way? Could I save the cross line alert setting in Tool Config?
[2014-10-22 08:04:01]
Hi SC support,
Is there any feedback on this? Still waiting
[2014-10-22 08:59:51]
User51760 - Posts: 108
Mark your line, open Chart Drawing Properties > SaveAs > TC1 - TC8, give it a Config Name and click the button SaveAs (TC1-TC8).
[2014-10-22 09:12:23]
I do have several setting in the Config. But the line properities has no default alert function. So it could not be save quickly
[2014-10-22 10:14:30]
Under Sierra Chart Version 1203 line alert works well setting it like this > https://dl.dropboxusercontent.com/u/5931986/sc_alert_for_line.png
[2014-10-23 02:31:50]
Really thanks a lot!!!
[2014-10-29 03:32:30]
We apologize for the delay. We were updating our documentation for this. It is now complete and explains how to do this:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Alerts
It is at the end of the Chart Drawing Alerts section.
Date Time Of Last Edit: 2014-10-29 03:33:13
[2014-10-30 01:25:17]
Hi SC support,
May I ask in this kind of setting, shall I still let the alert popup a window? I have not find any option in that settings. Thank you
[2014-10-30 02:35:03]
So you want the Alerts Log to open when there is a Chart Drawing alert triggered?
[2014-10-30 04:33:30]
Yes.Want to have a popup window to alert me. Because my PC always on mute mode.
BTW,I try to save the horizon line's chart drawing setting to config after I have do some alert setting. Later, I draw the horizon line and load the config, the alert setting seems still blank. Is that a bug?
[2014-10-30 04:59:37]
Refer to step 10 in this section here:
For the instructions to save a default Chart Drawing Alert configuration, carefully follow the step-by-step instructions for that in this section here:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DefaultChartDrawingAlertConfiguration
Do not follow any other instructions given by anyone else.
