Date/Time: Tue, 27 Oct 2026 17:54:04 +0000
delayed data
View Count: 353
| [2026-01-02 14:44:34] |
| Dennis B. - Posts: 303 |
Did the usual end of the month switch. SC data and then to rithmic and then back to SC data. Data is still delayed on all charts. Did this through Data/trade settings.
| [2026-01-02 15:05:30] |
| Sierra_Chart Engineering - Posts: 25297 |
You have no exchanges active . Activate them here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed You can find other exchanges to activate from this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-02 15:06:14
| [2026-01-02 16:27:04] |
Thank you for a quick response ! I did upgrade to ver. 2849, wow... my charts are all strange looking, borders etc.The old way was just fine,but will adjust.
| [2026-01-02 16:29:58] |
Sorry, forgot to mention,data coming in fine. Again, thanks...
| [2026-01-02 17:03:52] |
All of this is fully customizable: . my charts are all strange looking, borders etc.The old way was just fine,but will adjust.
Refer to this post: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off | Post: 431980 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-02 17:04:12
