Date/Time: Wed, 25 Nov 2026 22:08:28 +0000
Window Size Spreadsheet
View Count: 315
| [2026-01-02 08:30:59] |
| nicktrader - Posts: 817 |
Since the new window logic was implemented, the last settings for the spreadsheet window sizes are unfortunately no longer saved. Every time I open the platform, the spreadsheets open— I have them set to open automatically (General Settings/.../Start Up)— in the same (probably default) size. Is it possible to have them remember the last size again? I am running 2848. |
| [2026-01-02 08:52:31] |
| Sierra_Chart Engineering - Posts: 25483 |
This will be resolved. The size is saved, it is just not getting restored. So it will be restored properly upon updating Sierra Chart when we have this resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-02 08:53:02
