Date/Time: Wed, 25 Nov 2026 22:08:30 +0000
charts overlayed + crashing , unknown issue
View Count: 419
| [2026-01-01 23:29:24] |
| User790187 - Posts: 13 |
Not sure what is going on but my charts are completely messed up. Each chart in each chartbook has other charts overlayed ontop of it. No idea what to do. |
| [2026-01-01 23:55:39] |
| Sierra_Chart Engineering - Posts: 25483 |
We want you to disable OpenGL: Graphics Settings: Use OpenGL for Chart Graphics And then restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-01 23:55:50
| [2026-01-02 00:03:02] |
It is already disabled.
| [2026-01-02 17:13:20] |
Are you still having the problem, and are you still getting the same errors in the Message Log?
| [2026-01-02 17:22:16] |
I downgraded my install by going to help > install previous version that fixed the issue Date Time Of Last Edit: 2026-01-02 17:22:27
| [2026-01-02 17:53:50] |
We do not know why you would have a problem. We have no other reports of this. Does not make any sense to us. We do not observe anything like this.
