Date/Time: Wed, 25 Nov 2026 22:08:29 +0000
losing drawings when rolling over CT
View Count: 428
[2026-01-01 23:17:36]
User449884 - Posts: 238
Losing my chart lines when i roll contracts. Is this a new settings?
[2026-01-01 23:51:01]
We did a test now and we do not observe any problem with this. Go to the chart and go to Tools >> Manage Chart Drawings Window.
Do you see the Chart Drawings, that appear to be missing, there? You should.
Also refer to:
Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract
Date Time Of Last Edit: 2026-01-01 23:53:00
[2026-01-02 02:09:31]
OK, Chart >> Chart Settings >> Chart Drawings and Chart >> Update Chart Drawings to Current Symbol fixed it
thanks
[2026-01-02 17:15:33]
Keep in mind when you rollover a contract there is an option on the window where you select the new contract for "Also Rollover Chart Drawing Symbols". Set this to "Yes" to have the drawings update to the new symbol with the rollover.
