Date/Time: Wed, 25 Nov 2026 22:08:15 +0000
SC2813->2848 => oversized window bars
View Count: 413
| [2026-01-01 18:03:13] |
| User512353 - Posts: 198 |
Debian 13 wine 10.0 Updated SC from 2813 to 2848 The window bars of chart windows are now vertically oversized, reducing the internal chart window space. (See attachments for comparison.) This is really out of proportion and an esthetic impertinence. Is there any way to reduced the vertical size of the window bars? |
| [2026-01-01 18:36:20] |
The height of the Title Bar for MDI windows in the newer releases is controlled by the setting at the following link and the one below it: Graphics Settings: Window Title Bar But also look at the 7 other items below those that apply to the new MDI windows. Also refer to the following to understand the changes to these windows in the new releases and the settings that apply: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off | Post: 431980 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-01 22:22:22] |
| Sierra_Chart Engineering - Posts: 25483 |
That size actually is obtained from the operating system. So the question is why is there so much height for a title bar on your Debian system : The window bars of chart windows are now vertically oversized,
