Date/Time: Thu, 26 Nov 2026 03:41:27 +0000
Adjust bracket and stop and target to equal distance
View Count: 429
| [2026-01-01 02:34:16] |
| warpigs - Posts: 83 |
Hi. I’m wondering if this is possible. Scenario: I open a bracketed position with 2 contacts. Both contracts have a 2 point stop, one a 2 point target, and one a 10 point target. Then I decide to adjust the stop to 1 point distance. Is there a way to have the first target automatically move to a 1 point distance as well? |
| [2026-01-01 18:12:13] |
There is not a way to do this with the built-in tools in Sierra Chart. You would have to create a custom study to do this. Refer to the following: Automated Trading From an Advanced Custom Study https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-25 14:42:05
| [2026-03-25 14:40:42] |
| Sierra_Chart Engineering - Posts: 25489 |
There is this functionality, but it is not exactly what you are looking for: Global Settings >> Chart Trade Settings >> General >> Order Modifications >> Maintain Same Offset Between Target and Stop Attached Orders Documentation: Global Trade Settings Windows: Maintain Same Offset Between Target and Stop Attached Orders (Global Settings >> Chart Trade Settings >> General >> Order Modifications) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-25 14:43:14
