Date/Time: Wed, 25 Nov 2026 22:50:05 +0000
Anchored VWAP
View Count: 820
| [2025-12-31 20:29:03] |
| User49270 - Posts: 89 |
How do I plot Anchored VWAP on my chart without it carrying over to any symbol I change the chart too? Each symbol has to have its independent VWAP.
| [2026-01-01 17:53:46] |
The VWAP options in Sierra Chart end up giving you a study. Studies are not controllable on a per symbol basis, so there really is not a way to do what you are wanting, except to create a custom study. Keep in mind that even the "Tools >> Draw Anchored VWAP" ends up creating a study that is what drives the information. Therefore, it does not follow the controls for displaying on different symbols like other Drawing Tools do. This follows the study rules. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-01 18:28:19] |
| Sierra_Chart Engineering - Posts: 25484 |
We will look into this today. We should be able to prevent, the study from doing any calculations when using a different symbol from the original symbol it was drawn with.
| [2026-01-01 23:30:58] |
Please thanks, if not I would have to delete each VWAP when I change symbols or have a chart full of erroneous VWAPs
| [2026-01-08 21:39:05] |
Hi, any luck on getting Anchored VWAP to work as I need it to?
| [2026-01-09 00:01:49] |
Yes this is in the latest release 2858 but wait until 2859. This will be out later tonight.
| [2026-01-09 01:31:00] |
| [2026-01-18 00:40:42] |
After plotting on a symbol when I change symbols the VWAP is still on other symbols at the same date as the original symbol.
| [2026-01-27 05:24:51] |
We apologize for the delay. Update Sierra Chart to the current version: Software Download: Fast Update Open the Study Settings window for the instances of the Volume Weighted Average Price studies on the chart which were added by the Anchored VWAP drawing tool. Set this input to Yes: Anchored VWAP Tool: Only Show on Original Drawn Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-27 05:25:59
| [2026-02-04 09:36:00] |
Perfect, Thanks
