Date/Time: Wed, 25 Nov 2026 22:08:23 +0000
Bars Per Minute
View Count: 365
| [2025-12-31 16:38:19] |
| User184576 - Posts: 23 |
Hi, I'm using a 3000 tick chart. Is there an indicator that will count & display "Bars Per Minute"? If not, is this something that could be coded? Any assistance is appreciated. Thanks!
| [2025-12-31 16:54:14] |
| User719512 - Posts: 548 |
Do you really want bars/minute or pace of tape (which other searches might give you results)? Perhaps you could use a 1 min chart, use a couple calculations (Sierra subgraph divide/etc) and divide the volume in a 1min bar by 3000 and get that calculation (well, inverse). From this 1min chart, you can overlay this value onto your 3000 tick chart... |
| [2025-12-31 17:14:47] |
| Sierra_Chart Engineering - Posts: 25483 |
One study that you could use is this: Bar Time Duration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-31 17:15:31] |
Thank you for the direction, appreciate it!
