Date/Time: Wed, 25 Nov 2026 22:08:20 +0000
Different Charts During Replay are not synching
View Count: 528
| [2025-12-31 01:32:27] |
| shaanbullet - Posts: 4 |
I am trying to replay my footprint chart, DOM, and candle stick chart that are all on different windows. I have tried making the session times the same on all 3 charts, but it still didn't work. I am not sure what is wrong here. I am a beginner, and only started using Sierra charts this week, so obviously I am missing something. Please help.
Date Time Of Last Edit: 2025-12-31 02:03:24
| [2025-12-31 17:26:12] |
| Sierra_Chart Engineering - Posts: 25483 |
Another setting to check among all three of these charts is the Days to Load setting. Refer to: Replaying Charts: Replaying Trade DOM Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-31 23:41:08] |
That didn't work either, but I got it working now. I changed the replay mode to "Standard Replay" instead of "Calculated Same as real time". Not sure what is the difference, but it worked. Also, it seems that when I try to skip the time by minutes, it seems to break the synch again. So I have to speed up the time instead of skipping the time periods. For extra context, I am working with a footprint chart via tick range candle sticks, and a regular candle stick chart + the DOM. Date Time Of Last Edit: 2025-12-31 23:52:49
| [2026-01-01 18:03:14] |
With regards to synchronization during a replay, refer to the following: Replaying Charts: Preventing Loss of Synchronization Between Different Charts During Replay You should not have had an issue replaying multiple charts with the "Replay Mode" set to "Calculate Same as Real Time". Make sure you had the "Charts to Replay" set to whichever option you want to use to replay all the charts and not set to "Single Chart". Wwe wonder if what you were seeing was related to the "Processing Time in Seconds", which is not used for "Standard Replay", but is for "Calculated Same as Real Time". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
