Date/Time: Wed, 25 Nov 2026 22:08:21 +0000
Bid Ask size Histogram 100% HEIGHT?
View Count: 344
| [2025-12-30 21:46:37] |
| TopGunTrader - Posts: 313 |
Hi, I prefer in Jigsaw where each level touches the one above/below it NO blank empty spacing is there a way to get the bid/ask histogram FULL height so they touch and zero spaces? I've messed with it for 30+ mins and can't seem to get the same look. |
| [2025-12-30 22:30:10] |
You must be using a non-zero "Market Depth Combine Increment in Ticks" setting. This causes what you are seeing. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) We have noted the request to make the histograms full height when using the Combine Increment in Ticks. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-30 23:05:41] |
Thanks will be a fantastic improvement Jigsaw is buggy as hell but they do a LOT right with their DOM. I trade with Sierra now and SST's copy trader but still keep Jigsaw subscription to test it and TRY to get Sierra to look like it. They do some things brilliantly but dropped the ball on a lot too. Luckily I met a brilliant coder working on Momentum tails, that's their best feature and he's almost perfected it.
