Date/Time: Wed, 25 Nov 2026 22:08:18 +0000
subscription of trading package
View Count: 338
| [2025-12-30 08:13:09] |
| luke56 - Posts: 2 |
if i want to use interactive brokers for my data feed but amp futures as my broker. what package shld i sign up with?
| [2025-12-30 17:01:58] |
You can not do what you are stating. Sierra Chart is setup to allow you to use our Denali Exchange Data Feed instead of data from your trading service (such as Interactive Brokers or Rithmic). But the system can not take data from one external source (Interactive Brokers) and display it while connected to another service (whatever trading service you are using with AMP). In order to connect to data and trading services, you need to be on one of the "Integrated" packages. Refer to the information for the packages at the following link: Description of Service Packages and Pricing If you want to connect Sierra Chart to both Interactive Brokers and AMP, then you will need to separate installations, one for each connection. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
