Date/Time: Wed, 25 Nov 2026 21:56:11 +0000
LinkOrderID in custom Study
View Count: 387
| [2025-12-29 16:37:10] |
| Dean Casey - Posts: 4 |
Just confirming that i cannot access the Link Order ID from the tradelog within a custom ASCIL study, is this correct? Also can I request this feature? Exporting Trade executions with associated data in realtime via csv and multiple fills really jamming up how my system interprets a single trade when it has multiple fills. Thanks guys
| [2025-12-29 22:29:29] |
| Sierra_Chart Engineering - Posts: 25483 |
We will add this if it is not there.
| [2025-12-29 22:35:50] |
This is provided: s_SCTradeOrder.LinkID Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-30 03:14:55] |
Perfect! I was looking all over through the documentation trying to find it! Appreciate the quick response
