Date/Time: Wed, 25 Nov 2026 22:08:20 +0000
Searching a letter used in Keyboard Shortcut
View Count: 399
[2025-12-28 17:41:24]
User130696 - Posts: 119
Hope you are doing well.
How can I search for letter M" to find this has been used in which keyboard shortcut so that I come to know the entire sequence and its purpose that it has been used for?
[2025-12-28 17:56:25]
Tony - Posts: 738
If you are referring to Customize Keyboard Shortcuts, then if a certain key (or a key combined with Ctrl/Alt/Shift) is being used, there will be something displayed in the "Key Currently Used By:" box below, otherwise, the box is empty.
Date Time Of Last Edit: 2025-12-28 17:57:11
[2026-01-02 04:05:03]
That I know but in order to look-up what Action has what Keyboard shortcut, I have to serially click on hundreds of action items then after clicking on each I can see whats assigned, If I want to know if this particualr single or multipe Key(s) such as "S" has/have been assigned to which action, then I cant do it quickly.
Date Time Of Last Edit: 2026-01-02 12:17:02
