Date/Time: Wed, 25 Nov 2026 22:08:21 +0000
Stop Loss deleting bracket orders when moved.
View Count: 464
| [2025-12-28 01:33:05] |
| MarieXMarkets - Posts: 17 |
When I place a trade in simulated and test moving the stop loss it deletes all other orders. I tried hitting the BE button and again once it's submitted it deletes the bracket ordes. Hesitant to try it live - don't want to brackets to delete when I move my SL. How do I fix this? |
| [2025-12-28 03:23:16] |
| Sierra_Chart Engineering - Posts: 25483 |
When the stop order fills, it will cancel, its sibling order. But this is all. When you Move the Stop order, does it fill? Check the Trade Activity Log for this particular stop order: Trade Activity Log: Viewing Historical Trade Activity If another order is getting canceled, check the Trade Activity Log for the origin of the cancellation: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-28 03:25:14
| [2025-12-28 15:55:48] |
No, it is not when a Stop is filled. It's just when moved at all. Scenario: Place trade -> enter trade -> move stop loss to BE or just above -> hit enter -> everything deletes. No fills just simply moving it at all deletes everything. I want to be able to move it to break even or trail it manually and it not delete the lines, or entire order. ( This is im SIM - I am hesitant to do a live trade when this is how it's currently sequencing on SIM). Or will it function normally on live? thank you! |
| [2025-12-29 15:48:53] |
Regarding this: No fills just simply moving it at all deletes everything.
For one of the orders that is getting canceled, provide us the lines from the Trade Activity Log for that order: Trade Activity Log: Providing Trade Activity Log Data Lines to Support We recommend not doing any live trading, until we understand what the problem is. We do not know what the issue is at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-29 15:50:10
| [2025-12-31 15:32:06] |
"C:\SierraChart\TradeActivityLogs\TradeActivityLog_2025-12-31_UTC.Sim1.simulated.data" "C:\SierraChart\TradeActivityLogs\TradeActivityLog_2025-12-31_UTC.Sim1.simulated - Copy.data" When I follow the instructins these are the two lines from the most recent simulated tade in the trade activity log. Compressed this into a zip file to upload then you upload screen shows ( I've copied and pasted the upload screen error ) : ======================================================================== To upload an image of a chart from Sierra Chart follow the screenshot/image instructions instead. Do not use this Upload Files interface here for this purpose. Uploaded Files: TradeActivityLog_2025-12-31_UTC.Sim1.simulated - Copy.zip - Size: 2.39 KB - Delete - (Private) Make Public Error: No file was uploaded. -------------------------------------------------------------------- Could the error of the stop deleting once moved past entry be in the trade settings OCO or something - (I did detach stop from Parent order)? ***Upon sending it looks like the file attached, Date Time Of Last Edit: 2025-12-31 15:34:48
Private File |
| [2025-12-31 15:59:01] |
This is what we see: ActivityType DateTime TransDateTime Symbol InternalOrderID OrderActionSource ServiceOrderID OrderType Quantity BuySell Price Price2 OrderStatus FillPrice FilledQuantity TradeAccount OpenClose ParentInternalOrderID PositionQuantity FillExecutionServiceID HighDuringPosition LowDuringPosition Note AccountBalance ExchangeOrderID ClientOrderID TimeInForce Username IsAutomated
Orders 2025-12-31 09:40:10.518666 2025-12-31 09:40:10.518657 [Sim]ESH26_FUT_CME 411 Canceling order due to sibling fill 411 Limit 1 Buy 692650.0000000 Pending Cancel Sim1 [Test5] Close 410 0.00 Good till Canceled N Orders 2025-12-31 09:41:56.709415 2025-12-31 09:41:56.709409 [Sim]ESH26_FUT_CME 414 Canceling order due to sibling fill 414 Limit 1 Buy 692775.0000000 Pending Cancel Sim1 [Test5] Close 413 0.00 Good till Canceled N Orders 2025-12-31 10:10:19.714628 2025-12-31 10:10:19.714622 [Sim]ESH26_FUT_CME 419 Canceling order due to sibling fill 419 Limit 1 Sell 693275.0000000 Pending Cancel Sim1 [Test5] Close 418 0.00 Good till Canceled N You can see in all of these cases, the orders have been canceled, due to the other order, the Stop order filling. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
